08-27-2018 03:05 PM - edited 01-05-2022 12:41 AM
I have transferred my previous number from virgin mobile, but after I have changed the plan from only texting to a data one, there's a new number given to me and my previous number had become the alternative one. How can I change it back to the old one?
08-27-2018 03:17 PM
@suiris wrote:I have transferred my previous number from virgin mobile, but after I have changed the plan from only texting to a data one, there's a new number given to me and my previous number had become the alternative one. How can I change it back to the old one?
As soon as a number is cancelled, the cancelled number went back to the original carrier who own that number.
Is your Virgin number was given to you by Virgin?
Is there any chance that your Virgin number was ported to Virgin from Telus/Koodo/Public?
If yes, PM may be able to get your Virgin number back.
08-27-2018 03:09 PM - edited 08-27-2018 03:10 PM
@suiris No idea why your number switched randomly due to a plan change. Are you sure you did not change your number?
To have this looked up, you will need to send a private message to the Moderator_Team with your account info and they will get in touch with you shortly.
More info on contacting mods:
