Transferring add-ons
arunkrishnan185
Hi,
If I accidentally activated one add-on instead of another one by mistake as all these are closely packed in the site structure, how can I transfer them?
For example, if I activated a Phillipines calling add-on instead of an Indian one, how can I cancel the Phillipines one and change that to the Indian one?
Thanks for helping
1 REPLY 1
JK8
@arunkrishnan185
You would need to contact a Customer Support Agent if you accidentally purchased the incorrect add-on.
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
Hours of operation:
You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
  • Monday to Sunday: 6 AM to 10 PM EST
Keep an eye on the envelope icon in the top right hand corner for a reply from the CSA.
