06-30-2023 09:41 AM
When I try to transfer my number it says
Invalid phone number: Please enter a valid Canadian phone number. If you are transferring you Koodo Prepaid number, please contact a customer support agent by clicking need help found at the top of the screen.
But my number is a Canadian phone number.
06-30-2023 09:42 AM
the error " Invaid Phone Number - Please enter a valid Canadian phone number" is either because
If you are porting in from Koodo prepaid, you have to activate with a new number first. Once activation completed and you can make calls and recieve calls, then you will need to open ticket with PM support for a manual porting request.
if you are NOT porting in from Koodo prepaid but was re-attempting the activation a second time, you will have to open tickte with PM support and have them to clear up the earlier activation attempt.
Please open ticket with them by direct message:
