Transfer
Jeancoleman1974
You need to request to transfer my number agsin from Rogers. I missed the 90 minutes to respond. They are waiting for the request againg from Public
1 REPLY 1
@Jeancoleman1974
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
But if you are unable to reach a live support with the phone number I sent you, please message the the support team using this link instead:
**After opening the ticket, please monitor your community inbox (envelope icon on the top right), the customer support agent will get back to you in sending a message there.
