12-09-2023
01:12 PM
12-09-2023
06:16 PM
computergeek541
Hi
since yesterday after I transferred my number to public mobile i can not get any incoming calls .
i have done all troubleshooting steps but did not work.
12-09-2023 01:13 PM
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins. If you are not receiving calls and text on your PM sim card, and only outgoing calls work, then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
