06-16-2022 10:14 AM
Hi I did not fully transfer my phone number, and I cant send or receive text messages and its been over 90 minutes
06-16-2022 10:59 AM
06-16-2022 10:51 AM
@Dedoe call your old provider and ask them to start the process again as I mentioned leave your old sim in
06-16-2022 10:38 AM
how do i do that?
06-16-2022 10:33 AM
These 2 questions are key, if even one of them you answer no then you won't be able to complete your port and you will have to reinitiate the process
06-16-2022 10:18 AM
@Dedoe hi did you leave your old sim in to receive transfer request did you reply yes to text> is your old account still active?
06-16-2022 10:18 AM
@Dedoe can you make outgoing phone calls?
did you already reply YES to your previous provider's SMS
After you reply the message, it usually take around another 1 to 2 hours, keep reboot your phone every 30 mins for an update
BUT.. if you cannot even make outgoing calls, let us know.
