Transfer number
SUNILKUMAR
Hi all I have question that I want transfer my number from Rogers to Public mobile and my number is registered with my brother's in law's account. So how can I process it ?
eddieO
@SUNILKUMARmake sure you leave your Rogers SIM card in your phone initially as you should receive a confirmation text from them regarding transferring out your number. You will have 90 minutes to respond yes. After that you can remove the old SIM for the new PM one
hi @SUNILKUMAR
name does not matter, all you need is to have the correct account number and phone number when you submit for poring
slusagm
you might not believe, they don't care name.
you just need to give the Rogers account number.  But Rogers will also send you a text to your phone number and ask you to approve, you need to reply within 90 mins after getting that text from Rogers
TheSterlinger
@SUNILKUMAR  you can use any name you want to use here. Public mobile does not verify or check names.
Important thing is to ensure you usevthe correct Rogers account number when the system ask for it. Avoid using IEMI.
