11-19-2023
08:21 PM
11-19-2023
11:45 PM
computergeek541
I'm transfering my number from Koodo to Public.
Koodo says the transfer has gone through and cut my service but I have no service with Public.
11-19-2023 08:33 PM
Try to reset the phone with the new sim.
11-19-2023 08:28 PM - edited 11-19-2023 08:34 PM
Are you transferring from Koodo Pre-paid or Koodo post-paid @Druxilla
Aside from trying to reboot the device and resetting network connections, then consider the following:
If porting here from Koodo pre-paid, you'll need customer support assistance.
If porting here from Koodo post-paid, you can try the porting assistance folks (whose number I'll send you by checking your private message box here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
And here's how you contact customer support:
To contact a Customer Support Agent, send a private message to them by clicking here. You’ll need to be logged into your Community account for the link to work.
Watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar, or tap your Avatar down in Messages.
