Transfer from Koodo
bectacular
Looking for help getting my old Koodo number back.
8 REPLIES 8
You are welcome @bectacular , Glad that we could help you . Have a great weekend.
@bectacular wrote:
Thanks a lot!
bectacular
Thanks a lot!
Can you log into my account ?  You can initiate your port from in there .Welcome to PM.
@bectacular wrote:
Post paid. I just activated my SIM 20 minutes ago. Koodo account is still active.
Log into your public mobile account if you want to port Koodo to Public Mobile.
Welcome to Public Mobile 🙂
popping
You ported your Koodo number to PM.
Now, you want to transfer your number back to Koodo.  Am I correct?
If yes, make sure your PM number is active and ask Koodo to port your PM number back to Koodo.
kselmak
Is your Koodo account still active?
If you are prepaid or if selfserve refused to transfer it, please contact moderators
https://publicmobile.ca.ada.support/chat/
They will be able to complete it for you
If it's not active you should try activating it, then porting
For postpaid please login to your self serve, then go to plans and add-ons, then to change my number, then choose transfer number, key in the number and the form will appear.
I suggest you open your koddo account in another window to copy and paste into
bectacular
geopublic
@bectacular
Koodo prepaid or Koodo postpaid?
Is your Koodo account currently active?
