Error processing and now can start again with SIM
mw311
I was signing up for the first time with a new SIM. I choose new number because I have to go through the port from Koodo to public mobile. I had set up AutoPay with my credit cards and it spun a long time and then gave an error. When I try to start again the SIM says it's invalid. I got a couple of text messages from public mobile with my pin and rewards feedback. With the SIM in the phone is shows Public Mobile and I can send a text to someone. I can't login to my account.
7 REPLIES 7
You are welcome @mw311 . Glad that we could help you.  Have a great weekend .
@mw311 wrote:
All sorted out. Thanks.
mw311
geopublic
@mw311  Click here to register your selfserve account. If that doesn't work try the password reset link. If you are still having issues then contact PM for help.
Is your Koodo account a prepaid one?
@mw311 wrote:
I'll try logging in again. I have multiple browsers.
The rest I've already done getting to here.
At what point can I ask to have my koodo number ported?
mw311
Jb456
Sounds like you're sim actually activated.
Check your credit card if you were charged. If you were welcome to Public Mobile 🙂.
Test phone if you can call in/out , text, MMS pic text and if data works.
Check if you're self serve account activated at same time. Try logging in.
You may have to create the account again and you can do so by link below.
https://selfserve.publicmobile.ca/self-registration/
In your account you can start the port process if it's Koodo postpaid.
If it's Koodo prepaid you have to contact moderators.
Or private message at link below
gblackma
@mw311 means that your account was set up. Wait 50 minutes,  clear your browser, go to incognito/private mode and try to log into your my account again.  Welcome to PM.  If this doesn't work for you,  contact a moderator and explain your situation.  Click on the green questionmark in the white circle at the bottom right of your screen .This connects to the autobot Simon . Type moderator and follow the prompts to get to one (CLICK on account specific question and human and submit a ticket)
