05-13-2024 01:06 PM - last edited on 05-16-2024 09:30 AM by Dunkman
Hello, I’m having troubling transferring my US number through the app.
05-13-2024 01:24 PM
this question has been asked before and as @Yummy has suggested, you cannot transfer a US number to your PM account. You can make a selection from the available numbers, but there's no US numbers here at PM. If you have a cell with dual sims, you can use one for PM account and other for US account.
05-13-2024 01:08 PM
check here to see if your number can be transferred.
If so, ensure that your app store location is set to Canada not US.
https://secure.koodomobile.com/checktransfereligibilityparrot/default
05-13-2024 01:07 PM
Check here is your number is eligible to tgransfer:
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do?lang=en&appname=otherportal
I am not sure you can port USA number. Only Canadian as I am aware...
