Transfer Failure?
Agnely
Just subscribed and after waiting for a couple hours, I still am not able to text or call nor is my cellular data working. Please help, thank you!
14 REPLIES 14
Agnely
Ok I will try these again, thanks for your help!
@Agnely wrote:
iMessage is turned on, send as SMS is turned on
@Agnely
At least more features are working now. Looks like more a setup issue for your iPhone versus a PM service  or porting problem.
Maybe remove the phone number from  iMessage.  Then add the phone number back to iMessage.
Toggle airplane mode on, then off.
Or try another network reset of phone.
Agnely
@Agnely wrote:
data and incoming and outgoing calls work. Also, incoming texts work but, the only thing not working is outgoing texts. iMessage works just not default texts.
Is the SMS setting enabled?
Agnely
@Agnely wrote:
I can receive texts but then I cannot send texts
@Agnely
What happens when you removed Virgin SIM card?  Then select the PM eSIM in your phone settings.
Does data work?  What about incoming or outgoing phone calls?
Agnely
Agnely
I did network reset. And I have both physical sim - Virgin and ESIM - Public Mobile, I will try to take out physical SIM card now
@Agnely wrote:
yes, I replied YES
There very well could be a porting issue, but the part about outgoing text messages and data not working aren't porting issues. This means there's at least something else going on that needs to be addressed.
@Agnely
Any luck with reboot of phone?  network reset of phone?
If you have your old carrier SIM card, try to re-insert in your phone.  Any service?
Agnely
yes, I replied YES
@Agnely
As you wait for CSA help who may not respond until tomorrow morning, you can try a few basic troubleshooting advice: Reboot your phone, Network reset of phone (this will erase any saved Wifi passwords).
If you ported your number, did you respond yes to your previous carrier's port request text?
Agnely
thank you I will try
This sounds as if it coudl be an account set up/service provisioning issues. Please opne a ticket using the chatbot.  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
