Tracking phone
alexisbg
Help, a phone has been lost and location service is off making the find my phone function not work. I can see that the phone is on and has a 30% charge. I can make it make a sound, but we are not sure where it is. Can Public Mobile tell me which cell towers it is closest to so I can narrow the search. The phone is losing its charge and my time is running out.
1 REPLY 1
will13am
@alexisbg , Public Mobile should be able to assist with your request.  Initiate a ticket with the moderator team.  The moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. If use of smartform brings no joy, then use the following direct link to private message the moderator team. Refer to the following knowledge base article for additional information on the moderator team.  Good luck.
