02-26-2021 05:59 PM - edited 01-06-2022 02:12 AM
02-26-2021 07:04 PM - edited 02-26-2021 07:05 PM
@Danielleginab wrote:Can't get in my account or top up
Hi @Danielleginab ,
If you are having self serve account log in issues, try clearing your browser's cache and open a tab in incognito mode - this can help with finicky websites.
Your username is an email. Go the "forgot your password" route (like @JK8 suggests) if your password is not working.
02-26-2021 06:53 PM - edited 02-26-2021 07:02 PM
To use *611, you'll need to know your PIN number.
If forgot password link doesn't work for you, you'll need to contact the moderators.
To contact a moderator, there are 2 methods:
- Use the ticketing system for a faster response time. Click here and type moderator assistance, then select account-related issue, then select you need a human now. Follow the prompts to submit a ticket, or,
- Send a private message to the moderator by clicking here You’ll need to be logged into your Community account for the link to work.
02-26-2021 06:00 PM - edited 02-26-2021 06:01 PM
Can you give more details? Can you call 611 to top up?
If you forgot your password try the Forgot your password link.
