Time sensitive/ porting request
Suddenly103
Hi public mobile,
My phone number is not transferred successfully from the pervious mobile company. Can you urgently re- submit the porting request?
Andy85
I just saw your response @JYS
I will send you the number now! Please check your community inbox!
JYS
Hi @Andy85 could you please send me the number as well? I also input the incorrect IMEI number. Thanks in advance!
Ahmadjr
@Andy85 Thank you so much!
Andy85
@Ahmadjr Not a problem, if you are stuck at the porting step, I will send you the porting phone number. Check your community inbox for the information!
Ahmadjr
Hi @Andy85 ,
can you help me with this as well as I need to help with my port.
Andy85
Hi @Suddenly103 ,
I will send the porting phone number to you by private message so that you can re-trigger the process. I am unable to post it in the public form as this post will get deleted. Check your community inbox for details. Thanks
