03-24-2022 08:52 PM
I try to open ticket but credentialis not valid??? Cannot be... What to do?
03-24-2022 08:53 PM
If creating ticket does not work (as it did not for last few months), contact agent directly through personal mail. There is no live support at PM…
Watch for envelope in top right corner.
Send a private message to the CSA - agent by clicking https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
03-24-2022 08:53 PM
03-24-2022 08:58 PM
YES!!! Email to agent worked. Thanks a bunch! So fast answer and good answer.
03-24-2022 09:01 PM - edited 03-24-2022 09:02 PM
@Ali03 Keep an eye on your inbox. It's the envelope top rightish on these forums. That's how support will get back to you.
If you care to share what your issue is we can try to assist you if it's not something that needs to be looked at in your account. We are all customers like you on these forums so other than account related issues we can try to help you.
03-24-2022 09:13 PM
03-25-2022 02:10 AM
@esjliv wrote:
@Ali03 wrote:I try to open ticket but credentialis not valid??? Cannot be... What to do?
Hi @Ali03 , the credentials you need to log into as for the SIMon Chatbot ticket would be your Community credentials. Were you trying your Community or Self Serve information?
The ticketing system ask for both sets of login credentials (bth Community and Self Sevrve), unless of course used a reason for a forgotten Self Serve password for need to open the ticket.
03-25-2022 09:51 AM
@BeachNBeer wrote:If you care to share what your issue is
Many thanks. I forgot PIN and read only agent can help. Did not want bother asking; searched Help first.
