Texting
08-21-2022 10:22 PM
08-22-2022 06:41 AM
@Edward7 - some more details would be helpful, like are you new to public mobile (is this a new activation)?
Are you an existing customer that all of a sudden started having issues?
Have you changed phones lately since this issue?
Try:
- turning off your phone
- remove the sim card
- if you have another compatible phone around insert it into that phone, does all texting work? If you don't have another phone to test with, then gently insert the sim card back in
- restart your phone
Did these actions reset something on your sim/account to allow texts from other providers?
If still issues try to perform a Reset of your device's Network Settings.
This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before.
Iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
android:
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
08-21-2022 11:36 PM
08-21-2022 11:10 PM
lol that is their go to blanket statement, if you want to know how many feet in a yard, who the 27th President of the US was, or the capital of Nunavut the answer is quite simple....you clear your cache/clear your data...and boom problem solved
08-21-2022 10:47 PM - edited 08-21-2022 10:48 PM
@Timer wrote:do you have other device to tried your SIM on it.
or
- go to your text app clear cache/clear data,
- updated version of Messages app,
- check your software ios update date,
- and rebooting device.
Please understand that an app settings/app cache issue can't possibly prevent someone from receiving text messges only from a specific carrier. The phone and software has no idea of which carrier the text messages are coming from.
08-21-2022 10:33 PM
or
08-21-2022 10:30 PM
Try reboot your phone once
You just ported your number from another provider? can you receive incoming calls without issue?
08-21-2022 10:25 PM
Have you tried resetting your phone? This sometimes happens to me and when I restart the phone it works
