Texting pics
Patrick_R
Hi anyone else have problems texting pics?
Mine spin forever and never go through.
9 REPLIES 9
srlawren
@Patrick_R wrote:
Not sure why you felt the need to reply in that manner
@Patrick_R who?  can you please try at least tagging the person to whom you're replying, if not also quoting?  EDIT: also, in what manner? We're not mind readers.
Patrick_R
srlawren
@hycm53 wrote:
@porcupine wrote:
My data is off and i can send pictures
I can’t send pictures if I turn off mobile data.
@hycm53 either @porcupine's phone is somehow non-standard and allows MMS over Wi-Fi, or they are actually sending them over Wi-Fi with another service and not realizing it (e.g. iMessage, WhatsApp, etc); my strong hunch is the latter.  @porcupine are you an iPhone user?  Are the bubbles blue or green when you send picutres with your data turned off?
hycm53
Patrick_R
Not sure why you asked did robertwc not say that 4 hours before you.
His reply was helpful mentioning may need to turn data on.
Other systems have not needed data
Patrick_R
It was my data works ok now
frostbite
@slash407 wrote:
yes its a apn issue, i hope u have better experience than what i had with an older phone, you also have to leave data on when sending mms's
didn't robertqc say that 4 hours before you?
porcupine
RobertQc
@Patrick_RNo issues here. How is your Data? Usually MMS (picture text) not working is because your APN is not set up correctly or your mobile data is not working. Can you please confirm how your mobile data is?
The most likely cause is the APN. You need to configure (Or re-configure even if you have already configured before) your APN settings to be able to send pictures (MMS) and navigate on internet (DATA). Your "Mobile Data" needs to be activated.
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Iphone
Settings > Cellular > Cellular Data Options > Cellular Network
OR
Settings > Mobile Data > Mobile Data Options > Mobile Data Network.
Check your APN very carefully, make sure to note the MMS parts.
Name: Public Mobile / Mobile Internet
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
