10-06-2021 11:56 PM - edited 01-06-2022 03:43 AM
Hi there, I recently got started with a Public Mobile phone number and it's working great for calling, but for texting it doesn't seem to be sending or receiving texts. I'm testing the functionality out side-by-side with another Public Mobile phone and nothing is happening. I'm not sure what to do, any ideas?
Also, this is my plan if that helps:
I appreciate any help, thank you!
10-07-2021 02:00 PM
If you can't send or receive messages on your iPhone,
Why Is My iPhone Not Sending Messages,
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
Ensure you have the correct APN settings by visit Here link,
for iphone go to Settings > Messages > To turn iMessage on or off,
Turn your data on to send a Picture Messaging in world-wide,
if your data is off and your home internet wifi is on is not going through the Picture or a video Messaging,
you have to do this to is going through you will need to turn your data on to send a Picture or a video Messaging in world-wide,
make sure your Data is on.
and do again Rebooting your phone means to turn off your phone and turn it back on again.to refreshing your network...
and can you try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
and do Rebooting your phone
This is quick and simple,
and if still not fix it please you Have To Submit a Ticket To Contact Customer Support Agent by CS_Agent ,
Explain your issue to they can solve your issue, they are nice service Team the will help you 100%.
Here’s how to contact Customer Support Agent by CS_Agent,
Good Luck.
10-07-2021 06:49 AM
@EricMay wrote:Hey, thanks for the reply!
Good idea on the swapping, I tried it.
It's 100% not a hardware or software setting thing. Texting myself worked with the other phone's SIM card. Also I tried the troublesome SIM card in my other (previously-working) phone, and texting stopped working on that phone as a result. So I guess it has something to do with Public Mobile's service or the SIM card then?
Sounds like it's a SIM provisioning issue.
You'll need to contact CS for help.
10-07-2021 01:26 AM
@EricMay : Maybe try manually adding a $1 into your account and restarting the phone. If still not then you can try the self-suspend.
10-07-2021 12:51 AM
@EricMay Since you joined PM, the text never work? Incoming and outgoing both not working?
Did you port your number into PM? If so, are incoming calls working?
From what you said, you did try to put your PM SIM and it fails as well.
Maybe it is time to open ticket with PM CSA
To open a ticket with Customer Support Agent, click on the Bubble or directly at : https://publicmobile.ca/chatbot, do this to get to ticket open screen quicker
type: SMS not working
click : Need help with SMS Service
click: I can't send/receive texts
click: No
click Still not working
click "Click here to submit a ticket" .
If you have problems submitting a ticket, you can also send a private message to CS_Agents (but this can take longer):
10-07-2021 12:22 AM
Not an iPhone unfortunately, thanks for the reply though. 🙂
10-07-2021 12:21 AM - edited 10-07-2021 12:23 AM
10-07-2021 12:03 AM
@EricMay : Is this with an iphone? Can you send/receive to other iphones with either wifi or cellular data on?
10-07-2021 12:02 AM - edited 10-07-2021 12:25 AM
@EricMay wrote:Hi there, I recently got started with a Public Mobile phone number and it's working great for calling, but for texting it doesn't seem to be sending or receiving texts. I'm testing the functionality out side-by-side with another Public Mobile phone and nothing is happening. I'm not sure what to do, any ideas?
You don't need to send a text message to another phone number. The best way to test this functionality is to send yourself a text message (to and from the same phone number). This is because it eliminates other variable such as problems with the service of the other phone number and/or other device.
Since you do have a second compatible phone, I would suggest trying the SIM card in the other phone to see if this is a device setting issue (on the original device) or if it is a Public Mobile account issue. Once again, send the text message to the same phone number that is sending it.
