09-06-2025 10:28 AM
My plan says international texting is included, but does that mean texting to Europe from Canada is covered or is texting while I'm in Europe within Europe is covered?
09-06-2025 10:37 AM
The is one major disadvantage with PM. No international roaming besides US and Mexico. Unable to receive 2FA texts while traveling abroad. For some customers, this is a deal breaker.
I have used mobimatter.com for cheaper eSIM data travel options while traveling.
09-06-2025 10:30 AM - edited 09-06-2025 10:31 AM
@Idaron6 wrote:My plan says international texting is included, but does that mean texting to Europe from Canada is covered or is texting while I'm in Europe within Europe is covered?
Hello @Idaron6
Public Mobile only works in Canada, the United States and Mexico. There is no roaming outside these three countries. So it's only FROM Canada to Europe.
If I may make a suggestion though that might be worth looking into. You can download an app like TextNow, pick a local number to where you live now. Then, look at getting a eSIM from Airalo. Here's the link.
