Text
Text
I can call using my cell phone, but I can not receive or send texts.  After 5 Days I port my number to Public Mobile. Because of this, I can not receive my access code for conformation to access my account through text. Can any one help?
Julietz
I had same problem, it has been solved in few hours by opening a ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗"
@Text
You can click on Resend Code or Didn’t Receive Code and it will give you the option to send 2FA code by email.
hi @Text
was it just sms issue? can you get inbound calls?
if SMS, probably a problem with activation.  Please ask PM agent to refresh your account.
  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
