05-24-2024 08:56 PM
Does the text offer of 40 GB for $29.00 Replace my current subscription (not added to current one) ?
Plans
05-24-2024 09:29 PM
No kidding @uschy $4 for 28GB more data. PLUS at 4G speeds vs 3G speeds. Great value there.
05-24-2024 09:02 PM
Currently I have the 1 GB for $25.00 so this would be a great upgrade.
05-24-2024 08:59 PM
@uschy - Since you got an SMS from Public you reply YES and they will change the plan on your renewal date.
05-24-2024 08:58 PM
Hey @uschy
What is your current subscription? If you reply with YES, your plan will be replaced with $29 a month with 40GB of data.
