Text not working
Kashh8695
I use a iPhone 7
my texting worked Perfectly fine before I had no issues I can make phone calls I can receive phone calls I can receive text messages I just can’t send them the error every time
11 REPLIES 11
@Danitoo wrote:
I had an iphone and you need to have cell data enabled even of you do not have data, for texts to send.
Not so; iMessage/MMS must have data, SMS needs no data connection.
Best iPhone settings are: Settings >> Messages >> iMessage ON, Send as SMS ON, MMS ON >> Send & Receive: should show PM phone number and Apple ID email address.
If iMessage is OFF all messaging is regular SMS/MMS.
Well nobody else is saying anything...I think iMessage needs an internet connection (wifi or cell data). MMS needs cell data (paid or not) on.
Danitoo
@Kashh8695 wrote:
I checked to see if my iMessage or my normal text messages were the issue and my Imessaging works fine I shut it off, my normal texting won’t send.
I'm not an Apple guy so I'm just searching around and found that someone had success with the Home/Power button to do a full shutdown. Then turn it back on again.
Kashh8695
 @Kashh8695
Are you using iMessage? Is it *all* recipients?
If iMessage, are you able to change the setting to use SMS rather than going through iMessage. iMessage needs wifi or data to work otherwise.
After your post...
Kashh8695
I have restarted my phone I have factory reset my phone I’ve tried my Sim card in different phones I’ve done a lot it doesn’t work
Kashh8695
I have a $40 plan I don’t run out it’s unlimited
Stellaaa
Restart your phone and try again.
mimmo
@Kashh8695  what plan re you on one of the 10 or 15$ ones?  maybe you ran out of outgoing sms?
geopublic
@Kashh8695 wrote:
I use a iPhone 7
Are you on a limited text plan? Maybe you have used up your text limit?
