Text not delivered
Tkay
Hi there, suddenly I cannot send and received text?
gail709
Maybe you should send him a text. lol
@geopublic wrote:
  1. Did you restart your phone?
  2. Can you make calls?
  3. Are you on the $ 10 plan?
  4. Is today your plan renewal?
So many questions.....
lol and after 50 minutes...still silence.
geopublic
gblackma
@Tkay what's the make and model of your phone? If it's an IPhone. Enable sms, mms and group messaging . You may have been using Imessage over WiFi.
Jb456
@Tkay  is it one particular number or everyone? If it's one particular number, check if you accidentally blocked that number or set them to ignore.
Does the rest of your plan work?
And as @GR  suggested try the simple rebooting of phone
GR
@Tkay  start by restarting your phone
