Text messages
Aldonio99
Hello,
Can someone please port my number again. I CAN NOT receive or send  text messages
2 REPLIES 2
This might not be a porting issue.  A failed number porting doesn't prevent outgoing text messages.  A Public Mobile customer support agent can be contacted by using the chatbot.  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
hi @Aldonio99
Yes, PM porting support can help
   I will send you the number to PM Porting support team  Please check your community inbox
