04-12-2022 03:53 PM - last edited on 04-13-2022 06:07 AM by computergeek541
Any known issues of text messages not sending and/or receiving?
Been a ongoing issue since last night.
Account payment is good. Tried rebooting the phone multiple times. Am able to make phone calls no problem. Just no text messages.
Phone is a OnePlus 8 Pro on Android 11 if it matters.
Tried both the default messages app and Google messages also. Same issue.
Any suggestions?
04-13-2022 05:43 AM
Thanks for the help guys. I reached out to customer service and they pushed some kind of reset. Eventually it just started working as normal.
Not exactly sure if that was a fix or it "fixed" itself on its own. But I just received 50+ messages in one shot. Haha.
04-12-2022 06:44 PM
Oh ok the SMSC is for outgoing.
You can test your sim in your wifes phone when you can get it in your hands.
04-12-2022 06:37 PM
I'm located in ontario. the SMSC number is 1-647-580-0172 but is shown: 1-647-580-0172",145
and I'm not able to change it? not sure what that means?
upon some testing. i am able to send SMS/text. but nothing is coming in?
i confirmed with my wife's iphone...she's getting my messages but i'm not getting her's. as well as my friends have been messaging me all day but nothing is coming in.
i just opened a ticket...waiting to hear from customer support.....
04-12-2022 04:20 PM
Can you verify the SMSC # on the phone?
My phone has text messaging settings as follows:
in the texting app get into settings like with the 3 dots menu.
Then I have More settings. Then Text messages. And there shows Message Centre. The number should be 1-647-580-0172
There are other ways to see and set that number. It shouldn't get changed but things happen.
04-12-2022 04:05 PM
HI @luigibell78 I have checked the Telus outage page and don't see anything related with mobile service
But which city you are at?
as what @JK8 suggested try a network reset
or try to reseat the sim
If still not going anywhere, open ticket with PM CS Agent,
open a ticket with PM Support. Click on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
04-12-2022 04:01 PM
04-12-2022 03:58 PM
Tried. Not helping. I tried 2 different apps as well
04-12-2022 03:58 PM
Do not have another phone to test.
Voice and data work correctly.
04-12-2022 03:56 PM
04-12-2022 03:55 PM
HI @luigibell78 voice and data both work and just not text?
you have another phone to test?
did you try texting in another area , farer from where you had text problem?
