Text app issue
toddmatheson1
Please. Messages won't send a screenshot nor voice recording. They appear in the window but when I tap on them I see a circular moving line 'sending...' And a Choice to 'stop sending and delete'. Given enough time of not being aware of the problem they eventually appear as 'not sent'. MMS. Thank you.
toddmatheson1
Thanks hT, Moto play 5. APN entered, saved. reboot.
Tried, says image not sent. resending ... back to Messages. You: Image
back to imge, tiny clock. tap image, reads sending, trash can/stop sending and delete
porcupine
Make sure that your data is turned on
hi @toddmatheson1
what phone do you have?
first, make sure your Mobile Data is turned on
also, check your APN
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
