Test
benjaminhs
@benjaminhs
No worries....but it helps others if you leave it and just reply to your thread that you just got an answer from the moderators. It also means when you sort of solve your own issue that you don't choose any solution and let an oracle come along and decide if you solved your own problem or possibly someone else did. If the oracle chooses you ( the OP) they will explain why and then you get a solution.
Of course its frowned upon to just give yourself the solution.
If you ever want to change or not award a solution you can edit your original post by going to the 3 dots at the top right corner of your post.
Welcome to the community!
not a problems my dear Good luck with the solution.
your welcome to public mobile
with a Beautiful Service
you will be very happy
Good Luck
benjaminhs
Removed it once I saw the reply.
Thanks.
@benjaminhs
I sent two messages to the Moderator_Team yesterday and got no answer. I sent a third today and it was answered in 10 minutes.
Or did you remove your post because they finally replied?
sorry what are you doing !! you changed the original posting !
Or did you remove your post because they Moderator Team replied to you ?
anyway Good luck with the solution.
Only one way to you fix it explanation to moderator Team and the are nice service the will 100% help you
  • you can re send a private message to Moderator_Team by Click here
  • You’ll need to be logged in to your Community account for the link to work.
  • In your message put it, please include.
  • your account number,
  • your phone number,
  • your account PIN,
  • explanation to them nice Team and nice service
      Good Luck
