05-19-2024 07:04 AM
I activated my plan with a temporary number is there a maximum time limit before I can't no longer port a number from a different provider?
05-19-2024 08:35 AM - last edited 3 weeks ago
@008Bonds yes, you can port anytime as long as you account with the other provider is active
once you are ready to port, login My Account, go to Profile page and click Transfer phone number. Make sure you provide account number instead of IMEI for smoother porting experience
05-19-2024 08:32 AM
I'm trying out PM before committing long term so I have kept my other providers plan and number until I decided to port it to PM just want to make sure that porting is possible at anytime after activation.
05-19-2024 07:20 AM - edited 05-19-2024 07:21 AM
So you have not request porting during activation but picked a new number??
As long as the account you have with the old provider is active, you can still port you line with PM. And remember to provide PM the account number of your old provider
But if you have submitted porting request when you activated, you didn't really got a temporary phone number from PM. If a posting request submitted during activation, your old provider would have send you a text about the port and you need to reply YES within 90 mins. If you missed that, you need to ask PM to re-trigger the port request to your old provider
05-19-2024 07:15 AM
You can port number at any time
