09-11-2022 10:33 PM
Normally Public Mobile is an acceptible service, however, from my home in Courtenay, the signal strength is marginal. Can enyone tell me where the Telus towers are located so I can aim my signal amplifier for a better connection?
09-11-2022 10:53 PM
09-11-2022 10:37 PM
09-11-2022 10:36 PM
@Jim4 wrote:Normally Public Mobile is an acceptible service, however, from my home in Courtenay, the signal strength is marginal. Can enyone tell me where the Telus towers are located so I can aim my signal amplifier for a better connection?
This following site can be used as a guide but it won't always be up-to-date: https://www.ertyu.org/steven_nikkel/cancellsites.html?lat=52.000000&lng=-97.000000&zoom=4&type=Roadm...
The actual locations don't tell you everything either as different sites can have different configurations/be tunned differently and can also be affected by terrain.
