Telus WiFi
04-25-2022 02:19 PM
Does my Public Mobile membership give me access to the Telus public WiFi hotspots?
Other
05-05-2022 07:21 PM - edited 05-05-2022 07:23 PM
@popping wrote:Telus WiFi is available to TELUS and non-TELUS clients. You need to register before it lets you to connect.
https://www.telus.com/en/bc/support/article/telus-wifi-public-hotspots
They added the Koodo account to login to the Telus Wifi hot spot.
04-25-2022 04:43 PM
Telus Wifi has 2 WiFi services. One is for the clients of the Telus ISP service which will be auto login without prompting to login after setup The other one is for the general public.
Shaw WiFi has the same setup. My friend is with Shaw. He created a Shaw email address for me to connect to the Shaw client WiFi network.
04-25-2022 03:12 PM
Yeah, quite possibly. It usually isn't imperative as I will either have data or don't really need internet at the time.
04-25-2022 03:11 PM - edited 04-25-2022 03:11 PM
HI @JL9
With the hit and miss, I think you got mixed up with the public hotspot in the mall powered by Telus and those one available for Telus clients only
04-25-2022 03:09 PM
Did it work for you? I tried a couple other public hotspots (not Telus) and they seemed to be hit and miss.
04-25-2022 03:00 PM
04-25-2022 02:36 PM
HI @EugeneS I doubt it. But report us the good news 🙂
04-25-2022 02:27 PM
Try it. Use your account login credentials and see if it will let you in. Report back your findings if you like.
