05-16-2026 11:56 AM
I am wondering with the upcoming changes and my phone needing to be upgraded for the network (since it's not whitelisted despite technically being "compatible") if purchasing a phone model that Telus sells would work.
I can't afford much but I'd prefer to buy one outright rather than pay monthly and I'd like to stay with Public. I certainly can't afford to buy random phones and hope for the best. I'm just wondering since there doesn't appear to be a dedicated list of phones that work that if Telus sells it, then it should work right?
Thanks!
05-16-2026 05:54 PM
Thanks for your reply.
My son has a Samsung Galaxy A14 on Public Mobile and has no issue so maybe I'll consider that (I just found that out 😅).
05-16-2026 04:57 PM
Unfortunately, not all Telus phones will work with Public mobile.
According to PM, it is actually the phone manufacturers that need to turn on VoLTE for a specific mobile carrier. Since Public mobile only introduced VoLTE since 2022, their whitelist of phones is smaller than other mobile companies include parent Telus and Koodo.
Ideally, it would be best to check IME before purchasing phone. But that may be difficult. PM is aware of this issue and hopefully working on a solution.
Here is a short list of the more popular phones.
Apple iPhone 8 & above
-Pixel 4 and above
-Samsung S22 & above
05-16-2026 01:46 PM - edited 05-16-2026 01:46 PM
How can I check IME on a phone I'm buying online? I have been searching for some kind of list of acceptable phones and it feels like looking for a needle in a haystack. I have an Umidigi G100 that should be compatible but the IME says it's not.
05-16-2026 12:34 PM
When you find a phone you like and can afford ALWAYS check it with PM for compatibility.
Buying a phone form Telus will NOT guarantee it will fork with PM. ALWAYS CHECK IMEI with PM no matter how old or new or fancy your future phone will be.
05-16-2026 12:11 PM
Sorry, all providers are ending 3G Network and you need a newer phone
What phone do you have?
Or you can also check with Koodo and Telus and see if your phone will work there. But their plan charge could be slightly pricier
05-16-2026 12:06 PM
Telus has their own whitelist that may not be on the PM whitelist.
Best to stick to Apple, Samsung, Google and Moto (Motorola) later models.
Check out Costco for Moto on sale and also a refurbished phone if your budget is limited.
