11-11-2016 12:51 PM - edited 01-04-2022 06:14 PM
I'm in the Online Activation process for a new account, and am getting the following error when adding a Tangerine Mastercard as a payment method:
"Sorry, we are unable to process your credit card request. Please ensure your credit card details are entered correctly and try again. If you continue to experience problems, please contact your credit card provider for more information."
All information is correctly entered. I've contacted the credit card providor and they confirm the values are correct and that several $0.00 test charges from Public Mobile were received and accepted.
Is this a known bug? I noticed other people mentioning issues with Tangerine Mastercards (http://productioncommunity.publicmobile.ca/t5/Discussions/Payment-Method-Glitch/td-p/67889) What's my next step to create an account?
01-02-2017 11:05 AM
11-12-2016 06:43 PM
@marxau, generally, support is done through the forum, just as you have witnessed with this thread. The volume of issues is normally not as great as it is this past three weeks, and will usually be quick response and solutions.
Welcome to Public Mobile!
11-12-2016 06:33 PM
So I used another card (with an identical address) and it worked. I'm now a happy PM user!
This issue seems particular to Tangerine Mastercards. Is there a way to file a bug report on this beyond just this thread? I genuinely don't get how Public Mobile support works!
11-11-2016 11:01 PM
11-11-2016 03:32 PM
It is not working on autopay option too.
11-11-2016 01:21 PM
11-11-2016 01:20 PM
Well, if it's a known bug I'll use a different payment method for now. Hopefully this gets cleared up eventually though. Thanks everyone.
11-11-2016 01:14 PM
11-11-2016 01:10 PM
I've checked the address against my statement and it matches exactly. I've also contacted Tangerine and they say the charge checks are going through. I can even see them on my statement ($0.00 charges from Public Mobile), so I don't think that's an issue.
11-11-2016 01:04 PM
As mentioned above, the address has to match how the address is showing with your credit card company. The best way to match it is to view a credit card statement and see how the statement is addressed to you. Make sure you type in the address the same as on the statement.
You can also call into Tangerine and ask them if they can see what is causing the transaction to fail.
11-11-2016 12:59 PM
Make sure the address you,re entering matches what's on your account, that causes a lot of issues.
11-11-2016 12:53 PM
I used the tangerine mastercard without any issues. Could be their system in general is going a little weird. Maybe wait until after the sunday maintenance.
