04-26-2022 07:35 PM
How do I reset my account password when I don’t have access to the email I used to set it up anymore
My Account
04-26-2022 11:16 PM
Unfortunately if you no way of remembering or being able to retrieve your email, your only option is a CSA fixing it for you. You would need to answer verification questions.
04-26-2022 07:46 PM
HI @santanajarvis What is the meaning of Tana?
To reset your password, just open ticket with CS Agent directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
1. Start with typing: "Forgot log in information"
2. Then Clic k "Contact Us"
3. Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
04-26-2022 07:38 PM
You will have to contact agent for assistance. At the same time you can ask them to update your email/pass.
- Use the ticketing system for a faster response time (preferred method as Ticket is assigned and easy to follow up with CSA). Click Chatbot - Ticket and type ticket, then click on Contact Us, then click on issue you inquire about. Link for creating ticket will be presented.
- Send a private message to the CSA - agent by clicking Here
