Talk Issues duing calls
Jas9
Hello,
I am having issues during phone conversations where the other person on the line says that my voice keeps cutting in and out. I'm using a brand new Iphone 12, is it possible that I need to update my Sim Card?
will13am
@Jas9 , the SIM card has not bearing on your issue unless you are disconnecting from the network intermittently and even then it could be the phone or local network issues.  In any event, VoLTE is important to voice call performance.  According to this help article your phone is on the VoLTE whitelist.  I suggest disabling WiFi the next time you are making a phone call and checking whether the network connection drops down to 3G or not.  If the connection does not drop down to 3G then your phone calls are on VoLTE which enhances voice performance.
https://www.publicmobile.ca/en/on/get-help/articles/volte
hairbag1
@Jas9
the sim is a robust piece of equipment that will almost never fail if treated correctly. Try the sim in a different phone. I highly doubt the sim is bad though.
Jaysen
Hi!
You might change your SIM card or just change a pack of your phone. iPhone also has the setting of the phone call!
HI @Jas9
Problem like this could be device issue , but also could be the service
Try click Reset Network Settings first
if you have another phone, try PM sim there
And are you using Bluetooth or other headset?  Try with and without headset
and try change your network mode to 3G and check if it helps
