Tablets
05-10-2018 04:10 PM - edited 01-04-2022 04:15 PM
Can you use public mobile for tablets too like samsung galxy and ipad?
Joining Public
05-10-2018 06:30 PM
Fido has a data only plan for tablets (3 GB for $15/month). In their fine print, it also mentioned that this plan is only for eligible Fido post-paid customers with a mobile plan. Public Mobile's data only plans are expensive compared to other ones out there.
05-10-2018 05:32 PM
@josephbuckshon make sure you shop around to see if the data-only plans here meet your needs and budget. With public mobile, the most expensive thing you can do is select a single service (such as a data-only plan, or talk-only plan, or text-only plan). You get a small discount by adding a second service, and the largest possible discount by adding all 3 services. I undertstand you only need the one, so I'm thinking PM may not be the best fit for your tablet.
05-10-2018 04:36 PM - edited 05-10-2018 04:37 PM
@josephbuckshon wrote:i mean the samsung galaxy tab s3
As long as it's unlocked and you can set up APN, no sweat. https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-up-Data-APN-on-your-phone/ta-p....
05-10-2018 04:30 PM
05-10-2018 04:20 PM
@josephbuckshon wrote:im only looking for data on my tablet so do you think it would work with the sim card on the newest samsung galaxy tablet?
What do you mean by "the sim card on the newest samsung galaxy tablet"?
05-10-2018 04:17 PM
05-10-2018 04:13 PM
This service does not restrict usage to phones only. Tablets are fair game. However, there are very few tablets that have the phone apk installed. The last one that was produced for the North American market was the Sony Xperia Z3 compact tablet. Unless the intention is to get a plan without calling features, a tablet will not work so well.
