TAlk not working
JimBarr
Can’t dial out to a local number.   Plan includes unlimited provincial talk.
gpixel
@JimBarr contact customer support mods
click on the question mark chat bubble to the bottom right of your screen
type "no service"
(use the chat bubble options, then click "submit a ticket, click me" option)
*login using your community account
make sure to check your inbox(top right corner envelope icon) periodically, for a response
will13am
This could be an account provisioning problem causing local calls to be interpreted as out of province long distance.  Has the number been successfully called previously?  If so, an account reset may be required to address the problem.
popping
If you ignore the warning message, will it connect at the end?
If your call connected at the end, try dial 1 in front of your local number.
If your calls are not connected, your account may not be provisioned correctly.  Adding $1 to your account may trigger PM server to provision your account again.
You plan must be an old plan with unlimited provincial talk.  You may want to purchase a $5 500 Canada wide minutes or change your plan.  All PM plans come with Canada wide minutes.
Triguy
Try dialing 1 then area code.
