Swithcing plans
captainpc
My existing plan is till June 4th, which I already pre-paid for..
If I switch to a 30 days plan ($40/Month). Am I losing the $120 I paid or will the new plan use the existing credit?
1 REPLY 1
@captainpc   PM is prepaid provider and won't provide partial refund
If you change Plan using Change plan now, then PM will charge you new plan amount now and the unused days of the old plan will be forfeited, again, no partial refund
so, please schedule a plan change using Change plan on next renewal date instead.
