Switching my email
Felix5
How do I change my email I can’t seem to get in my old email so need to change it
HALIMACS
@Felix5
The email with public mobile is just a username.
You don't need to be able to access the original email address on your email account to use it as a username on the public mobile self-serve site.
So, you can continue to use it here to sign into self-serve.  You just need to enter the email address and the password registered with the public mobile self-serve site.
If you're having problems logging in, that may be due to caching issues with the public mobile self-serve site. Make sure to clear your cache and cookies and open them incognito tab to log in with this service.
hi @Felix5 you can change email by asking PM cs agent, only they can do that
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
Quigley
@Felix5
Unfortunately, you can't change your email address associated with your account yourself.
You'll have to get a Customer Support Agent to do that for you if you ask.
Use the Chatbot Simon to get a service ticket started first.
@Felix5 @To change email you need supports assistance
Getting help from agent
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get
Or get help right here in the community
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
