Switching from one plan to another...
Barryere
I'm wondering how this works, because I am currently on the $15 plan and tomorrow I have to pay and I adjusted my plan to the $25 plan, but the overview page says I owe $15 still.
Also, the overview says that my plan has expired...
7 REPLIES 7
Barryere
Okay, thanks.
popping
@Barryere wrote:
So for the $25 plan, I just put $25 into my account?
It depends on what is available fund in your account and the rewards you are getting.
Your plan $25
less: available fund in your account
less: $2 autopay if you have autopay enable
less: $1 per referee you have
ZfromVanC
Yes, adding funds to your account is a good way to make sure nothing funky happens with autopay.
Correct.
Barryere
Metal1967
@Barryere
If you chose to change plans at next renewal..just make sure your balance will cover the difference..or if on autopay should automatically cover it...
mimmo
If you futuredate the new plan all should be fine.
If you want add funds to cover the new plan cost to avoid an autopay failure.
Expired status is fine if service is working.
This is a good read     https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/EXPIRED-vs-SUSPENDED-AVAILABLE-FUNDS-vs...
