06-27-2017 01:45 PM - edited 01-04-2022 02:14 PM
For those of you that recently switched from Freedom and happen to be using an LG G6 (mine is factory unlocked).
If you've validated your APN settings, rebooted the phone and such like, try this:
Settings --> Networks Tab --> More --> Mobile Networks --> Network Mode --> Set this to GSM/WCDME/LTE auto
Restart phone for good measure and hopefully that works!
J
06-27-2017 03:59 PM
06-27-2017 03:13 PM
With the LG, it is very likely that you will need to do a factory reset to get the data working. I had to do one when I bought a new LG G4.
