12-25-2022 01:28 AM
Hello everyone 🙂
I switched from an old 3g plan to the promo 4g plan . Will I have to do anything on my end to enable the faster speeds or is it automated ?
Thanks
Jesse
Plans
12-25-2022 07:18 AM - edited 12-25-2022 07:19 AM
My device is currently on lte gsm and another network so i think im good
Cheers everyone and merry christmas 🙂
12-25-2022 01:37 AM
@computergeek541 @Oops my bad @computergeek541 @I trust @computergeek541 answer to be more solid and sound then my understanding of 24 hours @JesseDenny
12-25-2022 01:34 AM
@Handy1 wrote:@JesseDenny @Change your cellular data to 4g lte , also it can take up to 24 hours before you notice the difference in speed to take effect fully.
It's actually up to 48 hours.
12-25-2022 01:31 AM
merry happy holidays !!
handy1
12-25-2022 01:30 AM
@JesseDenny wrote:I switched from an old 3g plan to the promo 4g plan . Will I have to do anything on my end to enable the faster speeds or is it automated ?
The faster speeds will be in effect within 48 hours of the plan change. You'll want to make sure that the LTE network is enabled on your device, but it probably already is. If that's the case, you won't have to make any setting changes on your device.
