Switching eSim between phone/make an eSim only phone compatible with Physical sim
12-29-2023
05:08 PM
12-30-2023
09:03 PM
computergeek541
Hi does anyone know if there's geeking way to switch the eSim between phones?
Or is there anyway to to make an eSim only phone with usb-c or some extension that allows a physical sim card?
Thanks
Phones
12-30-2023 01:19 AM
I believe this question is already asked by you at https://productioncommunity.publicmobile.ca/t5/Get-Support/Switching-eSim-between-phone-make-an-eSim... and the answer is provided.
12-29-2023 07:50 PM
well, I know all what you are suggesting, but just waiting to see if there's someone have interesting solution or not
12-29-2023 07:16 PM
@MikeZha1 You can’t transfer eSIM to new phone you have to re buy one . With new phone download the app and log into your account, notice “shop SIM card now “ in my screen shot tap it and select eSIM and instal that’s it
12-29-2023 05:13 PM - edited 12-29-2023 05:15 PM
Yup…just purchase a new eSIM for the other phone…$5. This will be your only option if it is only eSIM compatible phone.
Better to get a regular SIM so you can pop it out and put in any phone you want if both have SIM compatible.
12-29-2023 05:09 PM
it'll be super awesome if someone can share tech tips, would definitely love to know
12-29-2023 04:37 PM
12-29-2023 04:34 PM
Thanks
![](/skins/images/C206B3E09108DC4A8294A110EB9CCA46/responsive_peak/images/icon_anonymous_message.png)
