Switching Plan - Data Boost
Buffy1009
Also, with the switching from legacy receiving 250 g and then my phone not making calls and plan was active.  Did I l lose that bonus?  Very frustrating not to talk to someone to ask but I want the remaining data I didn't use added to my account.  As I feel this was a glitch on Public Mobile's side.
Buffy1009
I didn't want to push the accept as solution but a gift is a gift and in law it is not right to have stipulations to a gift when you received it honestly.
@Buffy1009
You will loss your bonus data if you downgrade your plan but you won’t lose it if you upgrade your plan.
Did you download your plan recently?
@Buffy1009  You didn’t downgrade you plan did you ? If you did the bonus’s data will be removed .. but your not the first to mention calls not working first check
Outage map in your area:
https://istheservicedowncanada.com/
But to contact support to further investigate for you . Please
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send  direct  private message to support .
send  a  private message   To CS_Agents
