04-11-2019 06:04 AM - edited 01-05-2022 07:09 AM
I am on Autopay and my account says it is suspended. The card is active and has more than enough available funds. I logged in and did a manual payment of the amount owing but I still cannot make calls and the message still shows as inactive.
04-11-2019 10:37 AM
@geopublic wrote:
@MichaelM7154 wrote:Tried that. Get the message that I don't have an active account. Is there an expected turn around time after ithe issue has been sent to the moderators?
It depends on how busy it gets, but typical turnaround is between 30 - 120 minutes.
You are very lucky when it's only 30-120 minutes...![]()
04-11-2019 10:33 AM
@MichaelM7154 have you tried the lost stolen trick?
04-11-2019 10:29 AM
04-11-2019 09:43 AM
04-11-2019 09:11 AM
04-11-2019 08:30 AM
Sorry should clarify, after he’s made the payment I had to power off then on and it worked
04-11-2019 08:28 AM
04-11-2019 08:26 AM
Have you tried the good ole turning your phone off and then on again...I’m sure you have but I had to do that after I had the same issue yesterday!
04-11-2019 06:19 AM
04-11-2019 06:16 AM
Tried that and it did not work. How do I contact a moderator?
04-11-2019 06:14 AM
