Successful Telus Port! (I think)
11-13-2016 07:25 PM - edited 01-04-2022 06:18 PM
I'd just like to thank PM for offering this amazing deal!
I'll start off by saying I was with Telus previously and have successfully ported over here seamlessly. The process took literally no more than 5 minutes, including filling details and the actually porting of the number.
As soon as I reboot my phone, I was connected with Public Mobile and was able to text, call, and data instantaneously.
My only question though, is since I was ported successfully, shouldn't have I gotten a welcome to PM message saying that my port was complete? I'm only wondering because everything is working completely fine, I would just like to know if there's something wrong ahha.
Anyways, if anyone is looking to make the switch, or is on the fence, I can answer some questions to in the meantime!
Service
11-14-2016 02:17 AM
11-13-2016 11:27 PM
I was in the same boat as you. I switched from Koodo to Public Mobile and had no problems porting (was done in 15 minutes). Everything worked in terms of calling and texting, but I never received the congratulations text from them and was worried. I activated in November 3 and haven't run into problems, so I wouldn't worry about it.
11-13-2016 08:45 PM
Oh yes, I guess I did forget to mention, I have been able to receive calls and text the minute I set it up ahha!
Which, i'm guessing makes my port successful. This post was rather for curiosity sake's on whether the Public mobile text was actually a requirement for a port to be considered complete!
11-13-2016 08:29 PM
Check to see if incoming communications are working.
The fact that you can send texts, make calls, and use data does not necessarily mean that the porting is complete.
11-13-2016 07:48 PM
11-13-2016 07:46 PM
11-13-2016 07:27 PM
