Subscription
WKurt
Do I have 4g or 5g
Mojo7
If you go onto you public mobile app and look under your subscription tab, then go to manage subscription. It will tell you under current subscription.
@WKurt
We are members like you so we can’t access your account. You need to login to your account and check what plan you subscribe to.
hi @WKurt
first, whatever plan you have, you can still access the 4G and 5G network, just there would be a difference in speed depends on your plan.  If you have a 4G plan, your top speed is 100Mpbs, 5G plan would be 250Mbps
to know what plan you have, login My Account, go to Subscription & Add-ons page and you will see it there
WKurt
Do I have 4g or 5g?
