02-04-2025 12:36 PM
I had my account set up to change on the renewal date but it did not happen, how can I resolve this as a plan is no longer available. Anyone else have a problem like this?
02-04-2025 12:41 PM
Hey there, this has happened to some others as well, you may need to refresh the app, i suggest logging into your account from a web browser in private/incognito mode to make sure theres no old cookies/cache, and then see. If you had it set to change at renewal it should update. Hope this helps!
02-04-2025 12:39 PM
This seems to be an issues recently with a few of our members.
Just dm a CS_Agent and explain what happened.
02-04-2025 12:39 PM - edited 02-04-2025 12:39 PM
hi @Kurgan
it could be just a browser cache problem and your plan was indeed changed. Please try again using Incognito/private/secret mode on your browser to login My Account, or try using the PM app (logoff the app first and log back in)
if same, then submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
