3 hours ago
2 hours ago
You can chose between switching to the new plan NOW or on Your Next Renewal Date but be warned if you switch NOW you have paid the the old plan plus the new plan. No refund on unused days.
2 hours ago
@Ryan_79 how you change to that plan?? did you change via My Account or reply to a text promotion?? if text promotion, what did the text say about the end date of the promo??
3 hours ago
I changed to the promotional $35 a month subscription. What's incognito mode?
3 hours ago
@Ryan_79 wrote:How long does it take for me subscription to update?
The "Change Now"/Immediate plan changes have instantly. If you select the option to have the plan change at the time of next renewal, it will happen at that time, but that actual request will be accepted right away.
3 hours ago
@Ryan_79 did you just change plan or just renewed?? try login again using Incognito mode
