Subscription unsucessful
Wyatt0207
Trying to set up a new subscription. When entered sim # it says subscription unsucessful and wouldnt let me contiinue.
1 REPLY 1
@Wyatt0207
try this,
  1. Click Logout on top left of the screen
  2. Wait 5 mins for the system to configure on the back end.
  3. Then log in again using the Email  and Password.
  4. The app will then  sends a code to the Email again,.  Enter the code
  5. and you will see the prompt  'Confirm for Full Access' and your Activation will be completed after
if that does not work, open ticket with PM support Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after ticket submitted, CS Agent will reply to you the
